Check out Park Tool’s New Hydraulic Brake Bleed Kit
Premium kits for easy brake bleeding at home and in the shop
Brakes Gear News Tech
Park Tool’s Hydraulic Brake Bleed Kit
Park Tool recently announced a new premium Universal Disc Brake Bleed Kit, BKD-1 (for DOT fluid), and BKM-1 (for Mineral Oil). These kits are designed for both home and commercial use and include everything you need to bleed the most common disc brake systems in the market. The new bleed kits have bulked up designed to be ready for the rigors of daily commercial use. Like most bleed kits, it arrives with two syringes, hoses with shut-off clips, multi-size bleed blocks, bleed funnel. The coolest feature is a unique attachable syringe mount that allows the free movement of the mechanic and minimizing oil spillage.
BKD-1 Hydraulic Brake Bleed Kit BKD-1
  • Designed and built for home use and the rigors of daily commercial use
  • Includes two syringes, hoses with shut-off clips, multi-size bleed blocks bleed funnel and a unique attachable syringe mount
  • Housed in a rugged, reusable case
  • Machined stainless steel and 7075 aluminum fittings to service SRAM®, Hayes®, Formula®, Hope® and other brands of DOT fluid-based hydraulic brake systems
  • MSRP $117.95
BKD-1 Hydraulic Brake Bleed Kit – DOT
The BKD-1 Brake Bleed Kit will bleed most models of DOT fluid-based hydraulic brakes. Hydraulic systems need bleeding to remove any air bubbles and to inject new, clean fluid.
Check out the BKD-1 in action
BKM-1 Hydraulic Brake Bleed Kit – Mineral
The BKM-1 Brake Bleed Kit will bleed most models of mineral oil-based hydraulic brakes. Hydraulic systems need bleeding to remove any air bubbles and to inject new, clean fluid.
BKD-1 Hydraulic Brake Bleed Kit Features include:
  • Includes two syringes, hoses with shut-off clips, multi-size bleed blocks, bleed funnel and a unique attachable syringe mount
  • Housed in a rugged reusable case
  • Machined 7075 aluminum fittings to service Shimano®, FSA®, Magura®, Clarks®, Promax®, Tektro®, TRP® and other brands of mineral oil-based hydraulic brake systems
  • Replacement parts available
  • Brake fluid not included
  • MSRP $139.99
Check out the BKM-1 in action
Both sets are available now at ParkTool.com
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
Comments:
  • iggy says:
    That price is hilarious.
    • Francis Cebedo says:
      Hilarious low or hilarious high? We’ve had many cheap kits and they all pretty much leak and make a simple task difficult.
      • iggy says:
        Hilariously high. It’s a pair of standard veterinary syringes. You can get practically the same kit with brass fittings on ebay for less than a tenner.
        “We’ve had many cheap kits and they all pretty much leak ”
        I smell bullshit.
  • weak says:
    Hate to say it but he’s right….Kit (at most) should be half of what they are charging.
  • Joe T says:
    To be honest, Park has some tools that are a very good value (their hex keys and most of their wrenches are high quality and solid values), but they also have a history of charging silly high prices for other products given what you are actually getting. A perfect example is their 6.2 large sized torque wrench, which they sell for $126. That torque wrench is nothing but a rebadged Taiwanese generic torque wrench with Park Tool colors. The Taiwanese wrench generic wrench can be had on Amazon for $30. It literally has the exact same internals and external scale as the Park model but the Park model sells for 4 times the identical generic one. Another example is their new alloy chain cleaner. They are selling that thing for $90, and it is literally nothing but a metal enclosure with a scrubber, and a bay to hold some fluid and nothing more. It’s at most a $20 item being sold for almost $100. Laughable.
