Salsa Woodsmoke first ride
Elevating the hardtail with wheel size versatility
27.5 29er Cross Country Plus
Five different colors
Salsa must have high hopes for this bike as it is going to be available in five different colors for three different geometry configurations. From the sublime to the wild, this bike is going to turn some heads.
Woodsmoke 29 NX1 in Matte Black.
Woodsmoke 29+ GX1 in Khaki.
Woodsmoke 29+ XO1 in Warm Red.
Woodsmoke 27.5+ GX1 in White.
Woodsmoke 27.5+ XO1 in Green.
Continue to page 3 for ride impressions and geometry charts ยป
Wordpress Comments:
  • RobDink says:
    Something different & fun looking from Salsa! Always been a fan going back to the steel HT I inherited from an uncle in the early-mid 90s. Definitely want to throw a leg over one of these to test it out in all wheel sizes. I’m digging the fugly “dog with tail between its legs” look.
  • Durk Bentknee says:
    Sounds interesting but $2000 for a heavy NX build? I think I’ll hang on to my present hardtail for a while.
  • alias says:
    Curious why the author did not take note of the extreme BB height differences if one were to actually switch wheel sizes. A 4cm bb height difference is insane. Who other than the dealer benefits from using one frame for 3 wheel sizes? How many consumers will actually swap wheels?
    multi-wheel-size frames are pretty hoaky.
    • Francis Cebedo says:
      >> Curious why the author did not take note of the extreme BB height differences…
      On page 3 of the article, you’ll see the BB drop (height) on each configuration. Two are identical and one is 3mm lower.
      This is accomplished by a cool dropout feature that allows the height of the rear dropouts to be raised or lowered. For the front, the length of the fork is changed depending on configuration.
      We believe that most will select their preferred wheel configuration at purchase time giving this bike a broader market. Many buyers will take comfort that they can try a Plus size but still be able to switch to a 29er in case they don’t like it.
      And the minority will switch between two wheel sizes. winter vs. summer riding for example.
      • Arek says:
        Francis, how is BB drop the same as BB height??? They are not. While BB drop may remain fairly unchanged – as different wheel sizes have absolutely no effect on it, but rather fork length – the BB height will absolutely change and be quite visible between 27.5+ and 29.5+ wheeled bikes. While I’m not sure what the exact differences in BB height between the 3 bikes are, there will be a difference, no question about that – the 10mm difference in fork height between 27.5+ and 29.5+ builds helps a bit, but not enough to keep them constant.
  • jiw71 says:
    14 & 12 seems a tad high for air pressure. I weigh 210 and run 10 & 12 on a Stache 29+
  • Tom says:
    For those stressing about the BB height, take a look at the removable dropouts, and have look at different photos of different configurations on the internet, they have different shaped attachments which correct the BB height.
  • John says:
    Just bought a 2017 Woodsmoke XO1 27.5+ on sale. I thought I’d be buying a Stache but on test ride, I preferred the Woodsmoke’s 27.5 tire size for the type of riding I do. People shouldn’t worry about the Woodsmoke’s BB offset. It’s 65mm for the Stache, and 3 mm higher at 62mm for the 29+ Woodsmoke. BB offset is 59mm for the 27.5+ Woodsmoke with 130mm fork and 51mm for the 27.5+ ‘only’ Specialized Fuse, an 8mm difference.
