Specialized Levo SL vs. Levo – Which one is for you?
One, neither or both?
News Sponsored
The Levo SL and Levo were separated at birth and they took different paths.
The Levo and Levo SL have many similarities, with both bikes based on the Stumpjumper with 150mm of front and rear travel. Both are 29ers only with droppers and aggressive trail/all-mountain components. And both are Class 1 legal e-mtbs rated at 250 watts or below. If you’re in the market, which one is right for you? We try to break it down below in many different categories to help you decide.
Related: First Ride: Specialized Levo SL
Related: Specialized Levo SL: Everything you need to know
Appearance
Currently, very few riders want to announce to everyone on the trail that they’re on an e-bike. While acceptance is growing, it’s still evolving so being discrete and not calling attention to the bike is desired.
The Levo made strides in this area by having an internal, downtube hosted battery and not having a massive battery in the rear triangle where the water bottle usually sits. But its motor bulge by the BB area sits high with the Brose motor rotated upwards to allow easy removal of the internally mounted battery.
The Levo SL uses a much smaller battery so the downtube diameter is sleek and hardly bigger than normal bikes like the Trek Slash or Specialized Stumpjumper. Clever decals and tube shaping further mask the downtube and make it appear smaller. The motor area is smaller battery removal port so it’s as minimalist as possible.
Weight
One of the biggest differences between the two bikes is the weight. In size S-Works trim, large with tubes, weights are 38.25 lbs for the Levo SL vs 47 lbs. Where most of the weight was lost is in the motor which lost 2.4 lbs, now at 4.3 lbs. The battery lost 6.4 lbs when in the smaller, modular configuration.
This affects the bike in many ways including bike handling, portaging, putting the bike on vehicle rack or just moving the bike in the garage.
Levo SL motor and battery is much smaller and lighter but with less peak power.
Power
Torque is 35 nm for the Levo SL instead of 90nm on the Levo. Although rated wattage is nearly the same at 240w vs 250, Peak wattage is wildly different at 240w vs 560w for the Levo.
Power delivery too is unique with the Levo SL delivering little torque at very low RPMs but generating consistent torque from 50-120 rpm. The Levo, on the other hand, generates a lot of torque at very low rpm’s and then falls off above 90rpm.
This difference in power dictates a very different riding experience. The Levo owner can sometimes sit back and be taken for a ride to the top of the mountain. This can be done either in Turbo mode or Shuttle mode.
With the Levo SL, the rider is always an active participant in every climb. The rider is encouraged to spin and exert effort at all times. This creates a very rewarding trail experience for fit riders and even cross-country riders who want to cover a lot more ground. There’s rarely the feeling of the ride being too easy or ’not enough of a workout’. On the flip side, when the rider is tired or has half the battery left at end of the last climb, there’s no option to just get a powerful boot, shuttle to the end, which is quite rewarding on a Levo. Doing ‘one more lap’ is a no-brainer on the Levo but it requires more consideration on the Levo SL even when there’s plenty of battery left.
Levo SL is easy to pop off any small jump.
Handling
The greatest advantage of the Levo SL is in agile handling. The 9 lbs of weight on the more powerful Levo keeps it stable and planted but it also means it’s not as agile and not as willing to change direction. The Levo SL is an active participant in switchbacks and aerial maneuvers with its weight close to a non-assisted all-mountain bike.
In slow, tight climbs, it’s easier to change direction and lift the front of the bike. The motor assist and the well-supported suspension make the bike feel even lighter than it is. The chainstays of the Levo SL are shorter too by 15 mm now at an incredibly short 437mm. But when the climbs get steep and chunky, the 95 nm of torque of the Levo comes in very handy. Power moves and momentum make very steep and difficult climbs possible.
The Levo SL supports a range extender battery that mount on the water bottle cage.
Range and Modularity
Would you believe that the Levo SL with 360wh battery has the same range as the Levo with 500wh? We have indeed experienced it and it’s accomplished with a combination of factors:
  • bike is lighter by 9 lbs
  • the motor produces less peak power at 240 watts instead of 565
  • the motor expects the rider to contribute more at all times
  • the motor has almost no drag when the motor is off
  • the motor doesn’t put out a lot of power when in the most energy-consuming, low rpm states
The Levo has the class-leading edge of having an internally hosted 700wh battery. The Levo SL cannot match that but the trick up its sleeve is modular batteries. With an internal 360wh battery, it seamlessly integrates a 160wh battery in the water bottle cage. And the option of carrying multiple water bottle batteries on a big ride opens up possibilities. Another configuration is removing the internal battery and just running on water bottle batteries.
The Levo has a 700wh battery that’s easily field replaceable so owners have the option of carrying a second battery for 1400 wh of capacity. But the battery is long and heavy so it affect the ride quite a bit. A popular option is to stash the 2nd battery on the trail somewhere or in the car. Mid-ride, swap batteries and get ready to climb another 5-7000 feet.
The Levo can take on big mountain climbs with ease so it can be modded with more capable suspension.
Upgrade Paths
Starting from the same 150mm of all-mountain Travel, the Levo and Levo SL can both be modified to be lighter and more agile or heavier and more burly.
In our experience, the Levo is better as a burly, all-mountain bike. Put a 160mm fork and DPX2 rear shock and the bike becomes a capable descender for big mountains. Or better yet, put a coil front and rear suspension and it can become one of the most capable and comfortable bikes around with little concern for the pedaling downsides of coil suspension. With so much power on tap, getting burly, protected tires is a great option too when using it in very fast, rocky terrain.
The Levo SL, on the other hand, is better off optimized as svelte, trail machine. Put some 1400 gram wheels, trail tires optimized for the terrain and this bike can come to life. Experiment with carbon bits here and there and this bike might even see the south side of 34 lbs. And with little resistance from the motor, running out of battery during the ride may not be an issue at all.
One of the few downsides of the Levo SL is its high cost.
Cost
Everyone dwells on the $16k Founders Edition but that’s really that relevant since that is a limited edition collector’s bike. The real issue is the entry-level spec and the S-works spec. In this light, the Levo SL has increased in price significantly and that maybe its biggest downside.
Levo SL
Comp ($6,525)
Comp Carbon ($7,525)
Expert ($9,025)
S-Works ($13,525)
The Founder’s Edition ($16,525)
Levo
Comp ($4,950)
Comp Carbon ($6,950)
Expert ($8,250)
S-Works ($12,075
Resources
The 2020 Levo SL First Ride article is here.
The 2020 Levo SL Frequently Asked Questions is here.
The 1019 Levo First Look is here.
Comments:
  • Jeff B says:
    Francis,
    What a great comparison!
    I got my 2020 Levo Comp in November…
    I already built it up with a Cane Creek IL Coil (210 mm x 55 mm for extra 6 mm rear travel), upgraded the Lyrik to Ultimate 160 mm, running 27.5 x3.0 plus rear and 29 x3.0 plus front.
    It was the better choice for me….but I’m still drooling over the Levo SL Comp.
  • Browneye says:
    I test rode both, and while the SL is very smooth, the extra punch of the Levo Comp is way mo betta. JMHO
    I bought a Trance E+2 instead, saved a couple of grand.
