SRAM EX1 e-bike drivetrain review
Awesome shifting under power
Components E-bike
The EX1 group is finished off with robust chain, shifters and brakes.
The EX1 group has a robust chain, shifters and brakes.
EX1 X-Horizon Rear Derailleur
The X-Horizon derailleur is more robust to handle heavier loads. It features 12-tooth X-sync pulley wheels and is designed to handle 8 speeds of up to 11-48 gearing.
  • Speeds: 8
  • Cable pull ratio: 1:1
  • Max tooth: 48
  • Color: black
  • Pulley bearings material: Steel
  • Cage material: Aluminum
  • Weight: 289g
EX1 X-Actuation Trigger Shifter
The EX1 trigger shifter is a delight to use, as shifts are light action yet very positive. That double shift is gone and the rider will find themselves pushing hard on the downshift button to find that extra shift.
  • Speeds: 8
  • Max upshifts/downshifts: 1
  • Multi-position: Yes
  • Part weight: 122g
EX1 Chain
The high torque loads of e-bikes require tough components. The straighter chainline of EX1 allows the use of a chain that is wider and more robust than those found on drivetrains not specifically engineered for electric MTBs. It is a throwback that will last a lot longer than a normal chain.
Brakes
This is not a new system, as SRAM looked in its braking arsenal to piece together the ultimate stoppers. Thus it is a proven system with existing components to provide power and modulation. Components are the Guide R lever with its great modulation coupled with the 4-piston caliper from the Code gravity brakes. Sintered pads and bigger rotors complete the offering. Weight is 415g (based on direct mount, 800 hose, 160mm center lock rotor)
The EX1 shifter is rear only and fires off one shift at a time.
Pricing
  • E-Block cassette: $390
  • Rear derailleur: $142
  • Shifter: $48
  • Chain: $25
  • Brakes: $133 each
  • Crank: $50
  • Sprocket: $20
  • Total system cost: $941
Bottom Line
Is SRAM EX1 absolutely necessary for e-bikes? No, older systems will work. But does this provide a significant benefit? Absolutely. Bikes without this system will be at a disadvantage when it comes to performance and durability.
Something that surprised us during the test is the thought that this EX1 system might have use beyond e-bikes. Think powerful riders looking for the most robust system. And those looking for a simpler gears with bigger jumps may find this bullet-proof 8-speed with excellent chainline quite attractive, too. Well done SRAM.
Comments:
