Surface 604 Interbike 2015
Electric fatties, commuters and custom bikes
Fat Bike Interbike Sponsored post
Surface 604 is excited about getting people riding bikes and their 2016 line up is both utilitarian and budget friendly.
Video: Surface 604 Boar E350 Electric Fat Bike and E-Carbon Commuter
We catch up with Sam Atakhanov, the head of product development, and Dave Heighway, the VP of Marketing, for Surface 604 to discuss their brand ethos and newest bikes.
Surface 604 Interbike 2015 Booth
The entire ethos behind Surface 604 is getting people either riding bikes or riding more. That’s why they’ve designed bikes with electric assist systems, that are fender rack compatible.
The models are utilitarian and affordable. Their build kits include hydraulic disc brakes, 1x transmissions, and their most popular model retails for under $3,000.
Surface 604 is also trying to tackle peoples preconceived notions about what electric bikes can be. Many riders have complained about the weight of these bikes, so they developed a carbon commuter with an integrated battery pack that weighs 33 lb and will retail for $3,799.
Gallery: Surface 604 Boar E350 Electric Fat Bike, E-Carbon Commuter and Custom Woody Surf Bike
Surface 604 Interbike 2015 Gallery
of
The Boar’s aluminum frame has been completely custom designed in Canada by Surface 604. Most importantly, we’ve placed the battery (discreetly) in the down tube, keeping the centre of gravity low – lower than any other fat e-bike on the market.
  • Drive System: Bafang fat bike specific motor
  • Motor: 350w+ (peaks at 750w), Brushless hub motor provides silent peddle assist
  • Torque: 35/60Nm
  • Battery: 36V 13.3Ah / 478Wh Samsung Lithium Ion
  • Battery Life: Up to 80km (50mi) depending on mode
  • Weight Including Battery: M/L Size: 57lbs (26kg), S/M Size: 56lbs (25kg)
  • Frame: Tapered headtube, custom reinforced battery mounts, internal cable routing, post mount brakes
  • Fork : Proprietary design, tapered steerer, 150mm x 15mm thru-axle
  • Headset: FSA tapered 1 1/8″- 1 1/2″
  • Pedals: Wellgo platform
  • Rims: 26″ x 80mm single wall aluminum (standard), 26″ x 100mm single wall aluminum (upgrade option)
  • Front Hub: 150mm x 15mm thru-axle sealed bearing
  • Brakes: Tektro Auriga hydraulic disc, post mount, 160mm rotor
  • Handlebar: Promax aluminum 35mm rise, 670mm wide, 9 degree sweep, 31.8mm
  • Grips: Full length 122mm, black colour
  • Rear Derailleur: SRAM X5 10-speed
  • Shift Levers: SRAM X5 trigger shift
  • Cassette: SRAM PowerGlide™ 1070, 11-36T
  • Chain/Belt: KMC
  • Crankset: FSA 36T, Q-factor 209 Fat Bike Crankset, Small-Medium: 170L, Medium-Large: 175L
  • Bottom Bracket: FSA MegaExo 19 integrated, sealed cartridge
  • Standover Height: 730 mm S/M and 760 mm M/L
  • Seatpost Diameter: 27.2 mm
  • Tires: 26″ x 4″ Kenda Juggernaut (standard), 26″ x 4.5″ Kenda Juggernaut Sport (upgrade option)
  • Sizes Available: Small-Medium: 17.5″, Medium-Large: 19″
  • Price: $2,499.00
Surface 604 Boar E350 Torque Sensor
Power delivery to the motor is regulated by a torque sensor in the dropout hanger that senses how much torque you apply to the pedals; the harder you pedal, the more power the electric motor provides. The result is smooth power delivery and a natural ride much like a regular bike. The torque sensor has the added benefit of acting like a Battery Management System (BMS). The power going to the motor is instantly reduced when you reduce the torque and turns off completely when you stop pedalling. The effect is greatly reduced power consumption, longer range and longer battery life.
Surface 604 Boar E350 Motor
The Boar comes equipped with Bafang’s next generation geared hub motor available in 250w or 350w (depending on local laws governing power ratings). These new motors are incredibly silent compared with anything else on the market, weigh less and are so low-profile it’s hard to tell it’s electric. Geared hub motors have the advantage over direct drive motors in that they deliver high torque and are resistant to overheating when running at lower RPM’s. This is well-suited to carrying heavy loads up hills at slower speeds.
Surface 604 Boar E350 Battery
Surface 604 Boar E350 Rack
Custom front and rear racks on the Boar that will transform your bike into a pick-up truck (hybrid powered of course!). The front rack has attachments for saddlebags (panniers) and a large platform conveniently sized to fit a 12-pack of beer. The rear rack also fits standard saddlebags (panniers) and is rated for a whopping 42kg (100lbs) of cargo.
Surface 604 Boar E350 Controls
An electric fat bike that rides like a Ducati motorcycle.
Surface 604 E-Carbon
XC/Urban commuting electric bike.
Surface 604 E-Carbon Motor
Mid drive motor with the battery that is sleekly built into the downtube.
Surface 604 Custom Woody
Custom California '60s style surf culture bike.
Surface 604 has a passion for electric bikes. They're on a mission to change people’s perceptions about what’s possible on an e-bike and to get more people riding more often. That’s why they founded the company in 2013 with one simple goal: to build the ultimate electric bike – one that everyday people can afford.
