The Best Mountain Bike Lights for Night Riding
The best mountain bike lights for riders who hit the trails when the sun goes down
Lights News
 These are the best mountain bike lights for riders who hit the trails when the sun goes down
For most riders, we hit the trails during the daylight hours, but what if you work during the day? Better yet, what about the winter? We’ll you’d be surprised, but some riders prefer to ride in the twilight hours. Its cooler, peaceful, and riding at night can turn your local trails into a full new riding experience. You will need the right gear and what may work for a jaunt to work may not be the right lights to hit the woods. We’ve compiled a list of the best and brightest lights that are available. These mountain bike lights range from the super tech to affordable push-and-play models, so don’t think that riding at night is out of your price range or your tech ability.
Ultimate Power – See all and be seen
For those that ride the deepest and darkest of wilderness, you’ll need all the power you can get. These mountain bike lights are fantastic options for those that like to see all the trail ahead. What sets the following lights apart is the lumen count: a measure of the total amount of visible light in some defined beam or angle, or emitted from some source, in conjunction with the amount of power the light permits. An emphasis is placed on lightweight construction, durability, and overall pleasure in the user experience. So if you’re looking for the best mountain bike lights – look no further.
Lupine Blika R – All In One
Best of bike lights Blinka Lupine
Anyone who knows of Lupine lights knows, serious riders swear by them for night riding, racing, and touring. The unique design and all in one kit contain everything you need to use the Blika R as a headlamp and a bike helmet (with vents). Thanks to the FrontClick system, it is possible to change from headband to helmet in a few seconds. As for output, a massive 2100 lumens will light your way on the trails and a gentle reading light for when you’re hanging out at base camp.
Pros:
  • Superb trail visibility without overpowering
  • The Blika R app allows the user to assign lighting levels and special functions to any button
  • Great for night runs, hikes, and reading by the campfire.
Cons:
  • Many options and customizations could overwhelm users.
  • Vent only options mount from the factory, though a glue type could be used
Price: $520.00
buy now
Magicshine Monteer 8000
Magicshine’s most powerful mountain bike light, the Monteer 8000 is capable of 8000 lumens of actual max output. 10000mAh super high capacity battery pack and all-aluminum mount can take a solid knock from the trails. The max isn’t all this light can do, though. It boasts; 4800 lumens of floodlight, 3200 lumens of spotlight from LEDs on the bottom.
Related: Magicshine Monteer 8000S Bike Light review
Pros:
  • Super bright 8000 Lumens
  • The long-lasting battery on full blast and 4800 setting
  • A medium setting of 4800 is enough for most trail riding
Cons:
  • Not available in most shops
  • Could be overkill for most casual riders
  • The light clip can migrate down in rock heavy riding.
Price: $399.99
buy now
Niterider Lumina dual 1800
5 light levels plus 2 Daylight Flash modes; side lighting increases your visibility day or night. The all-new Collimator lens distributes a smooth, widespread beam pattern. Emits an impressive 1,800 lumens while in Boost mode; simply double-tap the power button to set the light to Boost mode. Runs 20 hrs at 100 lumens in Walk mode 6 hrs.
Pros:
  • Super sturdy fiberglass-reinforced nylon body casing and aluminum heat sink can take a beating on the trail.
  • Easy on and off with a secure mount works on the trails and the road.
  • Backed by NiteRiders lifetime warranty that covers any defects in mechanical components (housings, covers, mounts, and fasteners) and LEDs.
Cons:
  • Shifts slightly when knocked and changes the light direction slightly
  • No on helmet option available
Price: $160.00
buy now
Light and Motion – Seca Enduro
Dominate the trail well past dusk with the Light & Motion Seca 2500 Enduro light. With 2,500 lumens on high, this bike light emits nearly double the glare of the most car headlights, helping you to spot not only what rock gardens lie ahead on the trail, but also temporarily stun your buddy who is trying to make a night ride happen with a 100-lumen blinky light. The light path on the Seca has been engineered to enhance depth perception with the forward-focused upper. LED’s that penetrate the darkness, and bottom LEDs that are reflected and diffused downward to cover a larger field of vision.
Pros:
  • Attaches easily to helmet and frame for any use.
  • 6 cell battery, which offers a generous 2.5 hours of riding on high, or 5 hours in the medium.
  • The helmet mount is GoPro compatible and super secure.
  • Very water and snow proof if you plan to do some winter exploring
Cons:
  • 2.5 hours isn’t suitable for some users.
  • The battery pack is more on the heavy side for higher-end lights.
Price: $400.00
buy now
Lezyne Mega Drive 1800
The Lezyne’s Mega Drive 1800L Front Light comes with a specialized Tri-Force Optics lens, this helps provide the best possible lighting over a range of terrains, thanks to its brighter center spot in a large wide-angle pattern. The light is housed in a machined aluminum case, this provides protection from bumps and falls and any adverse weather conditions you may encounter.
Pros:
  • Looks great on carbon and alloy bike frames
  • Perfect for commuting and changing from bike to bike easily
  • Up to 148 hours of use can be obtained from one full charge (dependant on what lighting mode is used).
Cons:
  • No Bluetooth capability
  • Replaceable straps are only available from Lezyne
Price: $158.00
buy now
Cygolite Ranger 1400
Lightweight, durable headlight features 9 lighting modes for day and night use: Boost, High, Medium, Low, SteadyPulse, DayLightning, Triple Flash, Zoom, and Walking SteadyPulse mode alerts motorists with attention-grabbing pulses, while its overlapping steady beam continuously lights your way at night DayLightning flash mode bursts lightning-like flashes to make you stand out during daytime rides Hard-clamp handlebar mount with quick-release secures the light, even during mountain-bike adventures on challenging terrain Memory saves the mode you’re in when you turn off the light Light Lock lets you disable the light for transport or storage IP67 waterproof design allows worry-free, all-weather use USB-rechargeable lithium-ion battery offers 1.25–25 hrs. Run time depending on modes used; it recharges in just 3.5 hrs. Low-battery indicator.
Pros:
  • Lots of options for light pulse and beam selection
  • Memory saves the mode you’re in when you turn off the light
  • Great for commuting and light off-road riding
Cons:
  • The lights plastic shell casing can crack if hit on the trail
  • Longer time to recharge fully
  • Not a very wide beam for off-road use
Price: $130.00
buy now
Some riders prefer a helmet-mounted light and others prefer bar mount – the options are out there!
Self-contained and Bar-mounted mountain bike lights
If you’re looking to double up the duty of your bike light and get into some commuting and dabble in off-road riding – these are your lights. They are self-contained, meaning the battery and the light are all in the same unit. Most of these style lights attach to the handlebar but some are light enough to mount your helmet and bright enough for the trails alone. The best part is, if you’re a commuter these lights are sure to get you noticed and keep you safe on the road.
Bontrager Ion Pro 1300 RT
A USB-rechargeable front light with five modes for day and night and enough power to light up the full width of any trail. Ion Pro RT provides a powerful beam that lights up the entire width of any road or path.
Pros:
  • 1300 Lumens via high-power and runs; 800LM-3hrs, 400LM-6hrs, night flash-26hrs, day flash 22hrs.
  • Easily connects with Garmin and Bontrager ANT+ devices for always-on, battery status, and control.
  • Includes adjustable light mount that fits bars from 25.4-35.0mm Blendr compatible with a helmet mount.
Cons:
  • Single style Garmin mounts are sold separately
Price: $125.00
buy now
Blackburn Countdown 1600
Riding at night and having lights go hand in hand. Most of the time, when you’re riding at night, you have no idea exactly how much charge your light has left. You can take a guess based on your light’s specs, but it’s difficult to know precisely how much time you have. The Blackburn Countdown 1600 Front Light keeps the magic of the night ride alive by showing exactly how much battery is left on each light level, so you’ll never be left in the dark.
Pros:
  • Easy to read backlit display shows how many minutes of light remains in each of the 6 power modes.
  • It is rechargeable via a standard USB port and charges in about 4 hours.
  • Hefty drop-proof shell and waterproof to IP-67 standards
Cons:
  • Heavier than most lights on the list
  • Attaches uses at Blackburn proprietary mount that can interfere with bar space.
Price: $170.00
buy now
Magicshine ALLTY 2000
The Magicshine ALLTY 2000 is a quality light with a wide range of power settings and different beam patterns. You get reliable run time data displayed on a screen and a solid mount into the bargain, but neither the beam pattern nor the removable Lithium-ion battery is without their issues. As LEDs and batteries get more efficient, torch-style lights are increasingly dominating even at the high-lumen end of the market, and the ALLTY 2000 is one such beast. It’s a compact torch design with a metal and plastic body, a single button, and an LCD screen.
Pros:
  • The LCD screen is great for knowing run time and settings
  • Attaches super securely and uses a common “Garmin” twist style attachment.
  • 2000 lumens is a lot of power!
Cons:
  • Light can heat up the first couple uses but eventually stops
  • Not Bluetooth compatible
Price: $150.00
buy now
Cateye Ampp 800
An 800 lumen, high-powered LED light rechargeable comes with 5 different light modes, including flashing and stationary, and excellent side visibility. Cateye’s Ampp 800 Front Light is built with OptiCube lens technology, which, paired with the integrated cut-outs, spreads the light’s visibility and keeps your seen, and lets you see multiple different angles. To protect from all the road bumps and scrapes comes with an ultra-rugged, heavy-duty aluminum body construction.
Pros:
  • The battery light indicator shows three steps of battery life.
  • Great for light off-road riding and commuting
  • Mount is very secure for a strap style
Cons:
  • The screw style strap is very slow to change from bike to bike.
  • Not a very wide beam but more concentrated.
Price: $65.00
buy now
Garmin Varia UT800
Pair the Varia UT800 Smart Headlight with a Garmin Edge head unit for automatic adjustments to the ambient lighting outside, projecting the brightest beam on the darkest of nights and lowering its beam to save battery life at more radiant dawn and dusk hours. Not only does it adjust its beam intensity to the lighting outside, but it also matches the light beam to your current speed and ride profile to save battery life at lower rates with a lower beam and project more light when it’s needed at higher velocities.
Pros:
  • Easy integration with Garmin headunits
  • Five different lighting modes give you a wide array of beams for numerous ride types.
  • Excellent for commuting
  • Two different packages give you a bar/stem mount for road rides or a helmet-based.
Cons:
  • Not as bright as some options in the same price range.
  • If you don’t use a Garmin head unit the features are a bit lacking.
  • Mount options are hard to come by for multiple bikes.
Price: $100.00
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
Comments:
  • Tanner Mathews says:
    Interesting to not see Outbound Lighting in this list. Should be included in the list as they won multiple high praises from other high profile reviewers/publishers
  • Dan Maxfield says:
    Was hoping to see Outbound Lighting on here. I have tried Niterider and cheap amazon lights, but Outbound Lighting Trail and Hangover lights take the cake by a long shot! If you just need one light, then the Trail handlebar light is the best
  • Patrick Richardson says:
    Same with Moon Cycle lights. I’m using a Moon Meteor Storm Pro, boost mode of 2000 lumens, non boost max lumens is 1700. Only cost me £72!
  • Bruno Duque says:
    Nice lights but look at the prices… Pay 200 bucks for use 10/15 nights at year its too much. Next make a review for 30/40/50 bucks lights
  • Me says:
    You can’t talk about mtb lights and not mention Outbound Lightning.
  • David Lloyd says:
    There is no mention of my FLUXIENT off road bike light. 4 modes, flashing, two dipped and one crazy, can’t be used on ordinary roads as it blinds on coming traffic, LED. The battery will last 6 hours on low or flashing mode and 2 hours on main power setting. Price was £110. Very difficult to find a stockist who sells this bad boy now.
  • Teodor Ganchev says:
    You can’t talk about about MTB lights and not mention Outbound Lightning.
  • Tim Tucker says:
    Sounds crazy, but I do night rides with a Ryobi P721 work light – if you use some gear ties it hangs securely over the bars using the hook designed to hang it from 2x lumber.
    Beam is a super wide / bright 2400 lumens via a 20W LED chip. I can guarantee that it’s going to be brighter than the inflated ratings on most imported lights. A 4ah battery keeps it going at full brightness for hours and it’s easy to toss a spare (or two) in a bag to swap out.
    Retail for the light without battries is $80, but refurbs run around $40 and Home Depot runs deals every few months where you can get a light and 2 batteries for $100.
    A big benefit is that it’s not a single purpose buy — they come in handy for work around the house too. They use a hybrid design so that you can also plug them in if you’re near a power outlet.
    Only real downside is that it’s about 5 lbs with a 4ah battery and not 100% guaranteed to be waterproof.
  • Brandon Marshall says:
    FYI all,
    I have 2 Niterider Lumina dual 1800’s. One on the bars and one on my helmet. It absolutely does have a helmet mount option.
  • SN says:
    Outbound lighting is not listed cos at <800 lumens (if i remember correctly) its not worth the money! All you need is for another rider to come up behind you with brighter lights and you will start seeing shadows instead of the trail! If you want to compare a similar light, the Specialized Flux 1250 beats Outbound hands down with lumens and runtime.
  • Kevin says:
    Huh? No Exposure? Then not a list of the best bike lights, because they are the best. If you are using a battery pack then you are doing it all wrong if we are talking the best.
  • Ed says:
    You guys only hit the very run of the mill, or top end options. Magicshine has some lights in their lineup, like the MJ-906, that blow most of these other similar lights youblist out of the water. Don’t call this a “BEST LIGHTS” list. It’s more of a “Mainstream” or “we were paid to share these” lights list.
  • Ian says:
    Ah hello????? Outbound Lighting? In terms of build quality, warranty, performance and competitive pricing? And built in the USA????
  • Troy Warnken says:
    I just picked up a M6 lucifer light and could not be happier with it. Build quality is second to none. Great comfort on the helmet or with the headstrap. Intuitive button for changing the intensity of the light. It took a month to get it from the day I ordered it until it got to my house. That is from Czech Rep to Ohio.
