Weekend savings from Jenson USA
Save on bikes, tons of wheels, clothing and everything in between.
News
Fall savings at Jenson USA
This week the sales are wide and plenty, ahead you’ll find savings for the upgrades on you mountain, road and gear all around. So are you ready for the fall weather and leaves on the roads and trails? If not, check out some of the tires with extra grip and puncture protection. Are you ready for an upgrade on your winter bike or looking for early holiday gift ideas? Then shop the wheels and get the cyclist on your list an upgraded carbon hoops for the holidays. Because nothing says “I love you” like carbon bike parts – Let’s shop on!
SPANK OOZY TRAIL 395+ 29″ WHEELSET
PRICE: $487.99 – SAVE 25 % MSRP $649.00
Keeping up with tire trends is about as easy as winning a World Cup race. With the innovation of plus-sized tires, there’s no shortage of options on the market. It was with the development of new tire sizes in mind that Spank designed the Oozy Trail 395+ wheels. Spank’s new wheels accommodate plus-sized tires while maintaining compatibility with regular-sized tires. They give you the ultimate freedom to ride what you like and try new stuff out. Comprised of high-quality aluminum, the rims are light and stiff, providing optimal power transfer. Straight pull, triple-butted spokes are laced with alloy nipples. Spank’s hubs are meticulously crafted with a 3 pawl system using 30T engagement, making them fast and reliable. With adapters available for all popular dropouts, Spanks wheels are highly versatile. They are light and reliable, they fit a range of tire sizes, and they won’t break your bank. The Oozy Trail 395+ wheelset has it all.
buy now
REVIN CYCLING R35 700C CARBON ROAD WHEELSET
PRICE: $799.99 – SAVE 33 % MSRP $1,200.00
R35 Carbon Road Wheels are lightweight, reliable performance in a range of terrain and conditions. They’re tubeless compatible and include 3M tubeless rim tape. At the center are the iconic DT Swiss 350 hubs. They’re precision-machined with aluminum and optimized for efficiency with excellent engagement. Tying the wheel together, Sapim straight-lace spokes boast their excellent engineering and lightweight strength.
buy now
EASTON EA90 XD DISC 700C ROAD WHEEL
PRICE: $179.99 – SAVE 59 % MSRP $439.99
You can’t just ride offroad on any wheels. Some wheels can’t take a beating like a wheel that is designed for offroad riding. The Easton EA90 XD Disc 700c Road Wheel is designed for cyclocross. It was designed from the ground up specifically for the needs of the emerging generation of disc-enabled cyclocross, gravel, and adventure bikes. The rims are tubeless ready so you can set them up tubeless and drop the tire pressure for better traction and better ride quality. Hubs use Easton’s M1 sealed cartridge bearings and are compatible with 6-bolt discs.
buy now
WHEEL MASTER 29″ MAVIC EN323 WHEELSET
PRICE: $189.99 – SAVE 44 % MSRP $339.99
When it comes to your bike’s performance, nothing beats a new wheelset. An upgrade in wheels will have a significant impact on your bike’s ride quality. The Wheel Master 29″ Mavic EN323 Wheelset is a lightweight and durable wheelset designed for cross-country and trail riding. It has Mavic EN323 rims paired with Shimano hubs. The rims are double-walled for increased strength and durability. The hubs are disc brake specific and the rear hub is designed for 8 to 10-speed cassettes.
buy now
ENVE M735 32H DT240 BOOST WHEELSET
PRICE: $1,699.99 – SAVE 41 % MSRP $2,900.00
Ride without limitations with the newly reinvented M series Enve wheels. They’ve been reinvented to provide a smoother ride with more control and less harshness. The new M-Series now features Dynamic Impact Design, which sets out to solve the problems often associated with traditional hook-less carbon rim designs. It does so by introducing two new features that include a wide hook-less bead or a protective rim strip depending on the model. Not to bag on hook-less rims since they are in fact strong, lightweight, and are reliable for tubeless setups, but let’s be honest here, they are harsh and super susceptible to pinch flats!
Meet the future of gravity riding and racing, the M735. It is incredibly strong and debuts the most effective and lightest ant-flat system currently on the market (Enve’s patent-pending protective rim strip). the rim strip on the M735 offers unprecedented pinch flat resistance and provides you with the ability to run lower pressure to improve traction and rolling resistance. It also provides your precious rim a buffer between it and the trail in case you somehow end up flatting out. Ride without limits or restrictions and go all out as you were born to do. Your confidence in cornering and plowing through rock gardens will certainly get a boost.
buy now
REVIN CYCLING G21 GRAVEL 700C WHEELSET
PRICE: $1,199.99
The advent of wider road wheels, tubeless technologies, and disc brakes have facilitated and enabled the adventurer in every one of us to get out and explore roads and paths we never once even imagined. That’s where Revin steps in and reveals their high-performance offering for all who dare to set out and conquer every paved/unpaved road they can. The Revin Cycling G21 Gravel RD Wheelset offers super lightweight, reliable performance in a range of terrain and conditions. They’re tubeless compatible and are perfect for off-road adventures. At the center are the high-performance DT Swiss 350 hubs with center lock compatibility for more consistent and reliable braking performance.
buy now
Giro Syntax MIPS Road
PRICE:$100
When it comes to racing your road bike, you want to make sure you have a lightweight helmet that is aerodynamic and well protected. The Giro Syntax MIPS Road Bike Helmet that is a lightweight helmet that has slightly deeper coverage and high-performance features. It has a molded tough polycarbonate outer shell and an EPS foam liner. It features a highly-adjustable Roc Loc 5 Air MIPS system so you can dial in the perfect fit. The MIPS system helps redirect impact energy.
buy now
Supacaz Super Sticky Kush Galaxy Tape
PRICE: $39
Handlebar tape might not seem that important but it does serve an important purpose. Some tapes add extra grip to the bars and some tapes add extra cushion to reduce handlebar vibration translated to your hands. The Supacaz Super Sticky Kush Galaxy Tape is designed for riders who love getting high, up to the mountain that is. It features a super sticky PU top layer that provides a superior supple hand feel that stays tacky in all conditions, even when it’s wet. It has Kush Foam in the middle layer that provides the maximum dampening to reduce shock. On top of all this, it comes with aluminum bar plugs with expanders so your bar plugs won’t fall out. If you’re looking for the grippiest bar tape that provides a cushioned layer for comfort, then you’ll love the Supacaz Super Sticky Kush Galaxy Tape.
buy now
Argon 18 Krypton XRoad Frameset
PRICE: $599 (Marked down from $2000) SAVE: 70%
Riding in uncharted territory is what more riders are seeking these days. Being able to go from riding on the street to riding on the dirt is what gravel bikes are all about. Argons 18 Krypton XRoad Frameset is designed for the rider who isn’t content with having a bike that can do just one thing. It is a highly versatile multi-terrain bike that has clearance for up to 32mm tires and uses disc brakes for better performance in various weather and terrains like dirt and gravel. It features Argon’s AFS, or Argon Fit System, that provides added comfort for all riders.
buy now
Jamis Xenith Comp Road Bike
Jenson USA Memorial Day Sale
PRICE: $1199.99 (marked down from $2199) save 45%
Since the Earth Cruiser back in 1979, Jamis has been producing some of the highest quality bikes out there. They have created some of the most unique and innovative designs in the bike industry, so it’s no surprise to us that they continue to make some of the best bikes out there. For riders who are looking for a great all-around road bike, there is the Jamis Xenith Comp. It is a carbon framed, race ready road bike with excellent components. The Xenith Comp uses Jamis Road Dyad Plus T700/FRP monocoque carbon fiber. It has a 1-1/8″ to 1.5″ tapered headtube and uses an EVO386 carbon bottom bracket shell. ACE internal cable routing keeps the frame looking clean and is compatible with both Di2 and traditional cables. The frame has rider tuned seat stays with a spoiler bridge and oversized asymmetrical chainstays with direct mount brakes. The components are made up of Shimano 105 5800 components. It features Shimano 105 5800 2×11 shifters with a 105 5800 front derailleur and a 105 5800 rear derailleur. The crankset is a Shimano 105 5800 with 50/34 tooth chainrings and is paired with a 105 5800 11-speed cassette with 12-25 tooth gears. This combination gives decent climbing gears while also providing a great selection of mid-range gears to choose from. Alex AT 470 rims provide tubeless compatibility so you can use lower pressures and have fewer puncture flats.
buy now
Vittoria Mota TNT G+ 29” Tire
PRICE: $32.95 (marked down from $68.99) save 52%
Riding in wet weather can be rough, especially when you’re out on the trails. Dirt turns to mud and your bike can start riding like crud. When the conditions get tough, you need to tires that can fight back. The Vittoria Mota TNT G+ 29″ Tire is an aggressive tire for wet weather and muddy conditions. It has a generous tread spacing that sheds mud and debris so you can ride unfettered. The progressive sipe-width pattern provides excellent grip without sacrificing speed. The Graphene 2.0 compound performs well in wet conditions and the 4C compound in the tread increases the wear life so you can ride longer in between tire changes.
buy now
Fox Indicator SS Jersey
PRICE: $19.99 (marked down from $55) save 64%
The Fox Indicator Short Sleeve jersey is one part casual style, two parts performance. Made from 100% quick dry polyester, the Indicator wicks sweat quickly and dries even faster, keeping you cool and comfortable. A relaxed fit with raglan sleeve construction makes for a cozy, natural feel and added mobility in the ride position. Mesh side panels promote increased airflow and the drop tail design adds rear coverage while in the ride position.
buy now
Bell Sixer MIPS Helmet
PRICE: $150
Helmets are the most important part of riding a bike. Helmets protect your head from impacts. The Bell Sixer takes protection to the next level with MIPS technology that protects your head from rotational energy from certain impacts. This well ventilated helmet features Bell’s Float Fit Race system that offers a custom fit with three-way adjustability, Sweat Guide that pulls sweat away from eyewear, Progressive layering that manages the transfer of energies after some impacts, and an integrated breakaway camera mount.
buy now
X-Fusion Hilo Strate Dropper Seatpost
PRICE: $204.99 (marked down from $289.99) save 29%
Aggressive riders need to be free. Free to move forward or over the bike as the terrain calls for it. A seat post and saddle can definitely hinder this movement. Get it out of the way when you need it with an X-Fusion Hilo Strate Dropper Seatpost. It mounts To the bike with super clean internal seat tube routing, features a two bolt style head for perfect angle adjustments and comes with a cable actuated BAT remote. This remote can be mounted underneath the left-hand side of the handlebar where the front shifter used to be.
buy now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
